KB52394
Published: July 17, 2006
Some ioControl analog filter weight commands cannot select analog points configured on Ethernet I/O units
ioControl Professional
Problem was discovered in version: R7.1d
In ioControl Professional, the Set Analog Filter Weight command can be used with an analog point configured on an Ethernet I/O unit, however the Get & Clear Analog Filtered Value and Get Analog Filtered Value commands cannot select the same analog point.
The Ethernet I/O units include the SNAP-PAC-R1, SNAP-PAC-R2, SNAP-UP1-ADS, SNAP-UP1-M64, SNAP-B3000-ENET, and SNAP-ENET-S64.
This behavior is by design. The documentation for these commands will clarify which commands should be used with the I/O units.
