KB52483
Published: July 27, 2006
Unexpected reset behavior from surface mount style B6
B6
Problem affects firmware versions: 9159, 9159A, 9159B
The surface mount style B6 does not behave as expected when reset. Normally, the reset jumper, Jumper 7, is used to clear all analog outputs to zero scale, and to set the I/O configuration on the B6 to all inputs. After resetting, it is still possible to perform analog output writes without reconfiguring the brain board.
Opto 22 is researching this issue.
