- Configure Outgoing PPP as the default gateway and to dial on demand.
- Use ioManager, Communications→PPP Configure.
- Set “Outgoing PPP” = enabled.
- Select “Set Default Gateway to PPP” = Yes.
- Set “PPP Link Always Connected” = No.
- Other PPP settings must be configured appropriately for the modem and PPP access point used.
- While the PPP link is not established,
- Use an ioControl strategy to send communications using a “tcp:” type handle to a remote host that is not on the same IP Subnet as the brain,
or
- Configure SMTP Server IP Address of the email configuration to an IP address that is not on the same subnet as the brain, and activate an email event message.
- The brain resets once the outgoing PPP link is established.
