KB52626
Published: May 18, 2018
G4A8R, G4RAX, and B200 analog points are always scaled for degrees Celsius in PAC Control/ioControl
PAC Control Professional
ioControl Professional
G4A8R
G4RAX
B200
Problem was discovered in version: ioControl R7.1d
PAC Control R8.0a
R10.0a
When Mistic analog temperature input modules are configured for degrees Fahrenheit in PAC Control or ioControl, the configuration dialog still indicates degrees Celsius.
This is a known issue that affects Mistic analog points in PAC Control and ioControl. In Debug mode, the values shown are the correct degrees Fahrenheit values.
No engineering unit scaling is necessary. The scaling is part of the linearization that occurs in the brain and does not need to be changed.
