ioControl and OptoControl could crash if the following conditions were met while performing a Find operation:
- If from Configure mode, the debugger option When stepping, make sure the active block is visible, is checked (Configure→Options, Debugger tab).
[image1]
- The ioControl or OptoControl Debugger is running.
- Very large charts in a running strategy are closed.
- The Find dialog is used to find something within the strategy.
Keep the large chart that is causing the program to crash open while executing the Find operation under the above listed conditions.
Opto 22 has resolved this issue in ioControl, and has included the fix in a patch for OptoControl.
