KB52719
Published: March 19, 2007
Inactive Browse button for ‘Download file from I/O Unit’ command in ioManager
ioManager
Problem was discovered in version: R7.1b
Problem is fixed in version: R8.0a PAC Manager
If the Download file from I/O Unit command is selected from the ioManager(Tools→Maintenance screen, and the browse button for the Destination field is clicked, the button turns white and does not allow the user to browse directories.
To work around this issue, the direct pathname may be entered in the Destination field.
