KB52731
Published: March 19, 2007
‘Reset Points to Default’ command in ioManager resets Ethernet I/O units
ioManager
PAC Manager
Problem was discovered in version: R7.1b
Problem is resolved in version: R7.1c
Ethernet I/O units reset if the Reset Points to Default command is executed from the ioManager, Tools→Inspect, Status Write page.
