KB53125
Published: August 23, 2006
Modifying Custom Caption in windowless project, crashes OptoDisplay Configurator
FactoryFloor Software - OptoDisplay
Problem was discovered in version: R4.1a
If the Custom Caption in an OptoDisplay project with no windows is modified, OptoDisplay Configurator crashes.
The Custom Caption field is accessed from OptoDisplay Configurator menu item Configure→Runtime. When OK is clicked after modifying the field, Configurator crashes.
[image1]
The following steps will resolve this issue:
  1. Add a blank window to the project in which the Custom Caption needs to be modified.
  2. Save and close the OptoDisplay project.
  3. Reopen the OptoDisplay project, and modify the Custom Caption as needed.
  4. Delete the blank window.
  5. Save the project. The Custom Caption has been successfully modified.
  6. Resolution:
    Opto 22 is aware of this issue.
