KB53373
Published: January 5, 2007
Calibration of analog inputs from ioManager may not take effect
Problem was discovered in version: R7.0a
Problem is fixed in version: R7.1c
Calibrating an analog input from ioManager has no effect when calibration is done by selecting the File→filename.otg file. The Gain and Offset calibration commands are accessed by opening the .otg file, right-mouse clicking an analog input point, and selecting Calibrate. Calibration also did not work if done by highlighting Point and right-mouse clicking Calibrate.
[image1]
[image2]
Calibration is successful when done from the Analog Point Inspect window, Tools→Inspect, Analog Point.
[image1]
