KB53707
Published: March 9, 2007
ioDisplay ‘Synchronize at Runtime startup’ settings may not work for different user
ioDisplay Professional
ioDisplay Basic
Problem was found in versions supporting Synchronize at Runtime startup  R7.1 and earlier
Problem is fixed in version: R8.0a, PAC Display
The ioDisplay Synchronize at Runtime startup (synchronizes control engine clock to PC clock) option and the time interval at which synchronization should occur, may not work for a user who did not run Configure→Runtime in ioDisplay Configurator. A user who runs ioDisplay Configurator will not have this problem, but another user (account) who runs the project in Runtime without running Configurator, may have this problem. This can occur for example, when the Runtime project is run on a PC that is different from the one on which Configurator resides.
