KB53750
Published: November 29, 2007
Digital point’s IVAL becomes non-responsive while disabled in OptoControl debugger
SNAP-LCM4
Problem was discovered in version: B4.1d, Sep. 1, 2006
Problem is fixed in version: R4.1e
If a digital input point is disabled from OptoControl debug mode using the View Digital Point window, the IVAL does not respond to IVAL On/Off changes. Attempts to turn the IVAL On or Off while the point is disabled fails. When the point is once again enabled, the point’s IVAL responds to On/Off control.
