KB54041
Published: March 27, 2007
ioManager port configuration produces message 0xFFFFFFF3
ioManager
Problem was discovered in version: R7.1b
Problem is fixed in version: R8.0b PAC Manager
In the ioManager Configure Communication Port Control dialog, if the Used checkbox is selected, the message β€œAn error occurred in Communication Port Control configuration 0xFFFFFFF3” appears when the configuration file (.otg) is downloaded to the I/O unit. The communication ports, however, operate normally.
[image1]
Copyright Β© 2026 Opto 22. All rights reserved.
