KB54176
Published: July 12, 2007
‘make all’ fails in SNAP OEM Brain Open-Source Software CD
Problem was discovered in CD version: R1.0a
When building the open source package on a new computer using the R1.0a 060731-001 product CD, the make all fails.
The following is an example of the last few lines from the make all failure when the compiler is installed as
the root, the open-source is extracted, and the root directory in the open-source is changed to match the installation:
Opto 22 is aware of this issue.
