KB54324
Published: November 6, 2006
ioControl ‘Move Numeric Table to I/O Unit’ command changes input point IVALs
SNAP-UP1-ADS
SNAP-UP1-M64
Problem was discovered in version: R7.1f
Problem is resolved in version: R7.1h
When the ioControl Move Numeric Table to I/O Unit command is used in a strategy by SNAP-UP1-ADS or SNAP-UP1-M64, the IVALs for input points on the named I/O unit are changed. Input point IVALs should not change, only IVALS and XVALS for output points should change.
