KB54363
Published: July 9, 2007
Inconsistent results from ioControl ‘Generate Reverse CRC-16 on Table (32 bit)’ command
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
Problem was discovered in version: R7.1g
Problem is fixed in version: R8.0a SNAP PAC firmware, R7.2d Ultimate I/O firmware
The ioControl Generate Reverse CRC-16 on Table (32 bit) command may not work when used with SNAP-PAC or Ultimate I/O units.
