KB54388
Published: April 25, 2008
Assignment of unquoted hexadecimal characters to string variable in OptoScript may close ioControl
ioDisplay Professional
ioDisplay Basic
Problem was discovered in version: R8.0a PAC Display
R7.1d ioDisplay
Problem is fixed in version: R8.1a PAC Display
R7.1j PAC Display
R7.1j PAC Display
ioControl OptoScript may allow assignment of an unquoted hexadecimal sequence of characters to a string variable and cause ioControl to close out when the Test Compile or the OK button is pressed. OptoScript should not allow assignment of a number to a string variable.
Examples:
This string assignment makes ioControl close out:
myString =
000004100000FFFFF0D83002003C0000546869732077696C6C2074657374205443
502062792077726974696E6720746F2073637261746368207061642052414D2076696120
5443502E000000;
The following string assignments result in the expected compile error:
myString = 696C6C2074657374205443502062792077726974696;
myString = FFFFF0D84696;
