KB54410
Published: December 3, 2007
Downloading firmware from PAC Manager / ioManager to multiple devices may not complete successfully
PAC Manager
ioManager
Problem was discovered in version: R8.0a PAC Manager, R7.1b ioManager
Problem is fixed in version: R8.1b PAC Manager
Downloading firmware concurrently to multiple devices with PAC Manager or ioManager may not complete successfully on all devices. From PAC Manager's/ioManager's I/O Unit Maintenance window, the Results field indicates "Success" if firmware is successfully downloaded to a device, or "Could not open local file--failed" if it did not successfully download the firmware file.
