KB54413
Published: May 6, 2008
Control engine becomes unresponsive if wrong firmware type is downloaded
Problem was discovered in version: R7.1c ioManager
ioManager can incorrectly download non-UIO firmware to an Ultimate I/O control engine when downloading to a group of Opto 22 devices. From the I/O Unit Maintenance window (Tools→Install Firmware via Ethernet), the group of devices is selected from the IP Adresses list box. As a result, the Ultimate I/O control engine no longer communicates.
Opto 22 is aware of this problem.
