KB54480
Published: March 6, 2007
Variable names matching OptoScript command names may cause compiler problems in ioControl
ioControl Professional
ioControl Basic
Problem was discovered in version: R7.1f
Problem is resolved in version: R8.0a of PAC Control
In ioControl, if a chart, subroutine, or variable name matches an OptoScript command that is used in the strategy, the OptoScript compiler will report syntax errors that may be difficult to find. For example, a strategy with a chart named “AbsoluteValue” will have odd compiler syntax problems if the OptoScript command AbsoluteValue is used in the strategy.
In the example explained above about a chart named “AbsoluteValue”, the recommended chart name would be “chtAbsoluteValue.”
