KB54490
Published: January 4, 2007
Alarm sound may not activate if ioDisplay launched with PC shortcut
ioDisplay Professional
ioDisplay Basic
Problem was discovered in version: R7.1a
Problem is fixed in version: R7.1i
The sound configured for an alarm under Alarming Setup is not activated when the alarm is triggered if ioDisplay is launched from the desktop using a shortcut, and the sound file is located in the project directory.
The workaround is to uncheck the Use Project Directory box, and use the Browse button to enter the project directory path along with the sound filename in the Sound File field.
[image1]
