KB54495
Published: November 6, 2006
TCP connections to Modbus server not closed correctly on SNAP-PAC-R and Ultimate I/O controllers
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
Problem was introduced in version: R7.1a
Resolution is included beginning in beta version: B7.1h
Problem is resolved in version: R7.1h
The Modbus server on the above listed products does not correctly close TCP connections. As a result, available Modbus TCP resources may be leaked.
After connecting and disconnecting from the Modbus server two times, all subsequent connection attempts may fail. In addition, the Modbus server may prevent lower priority tasks, such as FTP, from executing. Improperly closed connections are corrected when the idle session timeout expires.
