KB54532
Published: July 5, 2007
Setting point's filter weight may cause filtered value to go to ‑1.#INF
SNAP-PAC-EB1
SNAP-PAC-EB2
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-B3000-ENET
SNAP-ENET-S64
Problem was discovered in version: R7.1h
Problem is fixed in version: R8.0e, for SNAP-PAC products
Setting the filter weight for a point, such as with the PAC Control Set Analog Filter Weight command, may result in a filtered value of infinity, 0xFF800000. From PAC Manager the value is displayed as "-nan", and from PAC Control, the value is displayed as ‑1.#INF, as shown in the following.
[image1]
