KB54622
Published: June 26, 2008
TransmitPtrTable and ReceivePtrTable commands may return corrupt data when used with Int64 vars
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R8.0a for SNAP PAC
Problem is fixed in version: R8.2a for SNAP PAC
R7.2h for Ultimate I/O
If the TransmitPtrTable and ReceivePtrTable PAC Control/ioControl commands are used with a pointer table that has pointers to 64 bit integer variables, then the returned data (from ReceivePtrTable) may not return the values expected.
