KB55091
Published: February 21, 2007
‘Set I/O Unit from MOMO Masks’ ioControl command affecting input IVALs on SNAP-PAC-S1 to serial I/O unit
SNAP-PAC-S1 Controller Firmware
Problem was discovered in version: R7.1h
Problem is fixed in version: R8.0a
Input module IVALs are changed when the ioControl command Set I/O Unit from MOMO Masks is used with a SNAP-PAC-S1 and a serial I/O unit. Digital inputs with IVALs previously in the ON state, are changed to the OFF state. Their corresponding XVALs indicate they are actually ON.
