KB55105
Published: April 3, 2007
CPU usage may increase when OptoOPCServer accesses I/O tags
OptoOPCServer
Problem was discovered in version: R7.1a
Problem is fixed in version: R8.0a
The computer’s CPU usage may climb (as measured by Task Manager or Performance Monitor), when OptoOPCServer accesses the memory map of I/O units (MMIO type, OPC Item ID) over a network that uses wide area technologies such as a gateway, router, a VPN over the internet, or a slow network.
ioDisplay accessing I/O tags directly from the I/O unit can also cause high computer CPU usage. ioDisplay uses OptoOPCServer to access the I/O data.
