KB55166
Published: July 9, 2007
‘Set End-of-Message Terminator’ may cause problems if set to null when used with ioControl file comm handles
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R7.1h
Problem is resolved in version: R8.0a SNAP PAC firmware, R7.2d Ultimate I/O firmware
The Set End-of-Message Terminator command may cause problems when used with file communication handles if it is set to 0x00 (null). For example, if it is used with the Receive String Table command, the command fails and reports error –44.
