KB55177
Published: January 5, 2007
ioDisplay alarms not always showing correct state when using Condition tag
ioDisplay Professional
ioDisplay Basic
Problem was discovered in version: R7.1e
Problem is fixed in version: R7.1i
Alarm points set up with discrete tags and configured using a Condition tag, do not always show the correct alarm state.
An active alarm is shown in the alarm graphic if the alarm state is true and the Condition tag becomes false. Under these circumstances, the alarm graphic should not show an active alarm.
Additionally, at Runtime startup, if the alarm is set (evaluates as true) and the Condition tag is true, an active alarm may not appear in the alarm graphic.
[image1]
