KB55182
Published: February 21, 2007
‘IVAL Set I/O Unit from MOMO Masks’ ioControl command not setting disabled serial I/O unit
SNAP-PAC-S1 Controller Firmware
Problem was discovered in version: R7.1f
Problem is resolved in version: R8.0a
The ioControl command IVAL Set I/O Unit from MOMO Masks does not set the IVALs to the specified mask values on a disabled, serial I/O unit.
