KB55540
Published: August 11, 2008
Uninstalling FactoryFloor R4.0b and reinstalling FactoryFloor
FactoryFloor Software
Problem was discovered in version: R4.0b
Problem is resolved in version: R4.1a
After uninstalling FactoryFloor R4.0b, FactoryFloor cannot be reinstalled.
To resolve this issue, perform the following:
- Using Windows Explorer, navigate to C:\Program Files\InstallShield Installation Information. If this folder is not visible, it may be “hidden”. Choose Explorer Tools→Folder Options, and change the folder’s attributes to show hidden files.
[image1]
- The folders are named as “Globally Unique Identifiers” (GUID). Under each folder, search for a Setup.ini file and look for the line beginning with "AppName=". If the application name refers to the uninstalled FactoryFloor version, then use the name of that subfolder in place of the term "GUID" in the steps that follow.
- Select Start, Run, and run regedit. Search for the following keys and if found, delete them.
- HKEY_LOCAL_MACHINE\SOFTWARE\Opto22\FactoryFloor
- HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\GUID
- HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\InstallShield_GUID
- HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\InstallShield Uninstall Information\GUID
