KB55618
Published: March 9, 2007
Duplicated metafile graphic not visible in ioDisplay
ioDisplay Professional
ioDisplay Basic
Problem was discovered in version: R7.1j
Problem is fixed in version: R8.0a PAC Display
In ioDisplay Configurator, duplicating a pasted metafile graphic (Edit→Duplicate) after dragging one into an ioDisplay window from SymbolFactory, results in an invisible, duplicated metafile.
Instead of using Edit→Duplicate, use Edit→Copy, followed by Edit→Paste to duplicate the metafile graphic.
