KB55814
Published: June 25, 2008
I/O unit may go offline when PIDs are inspected from ioControl Debug mode
SNAP-UP1-ADS
SNAP-UP1-M64
Problem was discovered in version: R7.1h
Problem is fixed in version: R7.2d
From PAC Control Debug mode, double-clicking on an I/O unit from the strategy tree displays the inspect window. Point information is shown by default (Show: Points). If instead Show: PIDs is clicked, the I/O unit goes offline.
To work around this problem, switch back to Show: Points and select Communication Enabled: Yes. Select Apply to enable the I/O unit.
To view the PID information, find the I/O unit in the Strategy Tree and double-click the PIDs folder to view the PID data.
