KB55848
Published: March 8, 2007
Serial port on SNAP-PAC controllers may return errors including -52
Problem was discovered in version: R7.1h
Problem is resolved in version: R8.0a
The RS-485 serial port on SNAP-PAC-S1, SNAP-PAC-R1, and SNAP-PAC-R2 controllers may not be properly initialized to communicate to serial I/O units if an I/O unit was not configured with an address of 0 through 3. Several errors may be reported, beginning with error -52. The resulting errors however, cause the port to be properly initialized the next time the strategy is started. The serial port alternates between being properly initialized and not being properly initialized.
