KB56192
Published: July 9, 2007
Null pointers assigned to any I/O point may eventually cause a controller reset
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R7.1h
Problem is resolved in version: R8.0a SNAP PAC firmware, R7.2d Ultimate I/O firmware
Using an un-initialized pointer (null pointer) to any type of analog/digital, input/output point, may eventually cause a controller to reset.
For example, in this Move to Pointer instruction, if pMyDigitalOutput is null and is assigned to a “digital output point” pointer, a -69 error (“Invalid parameter (null pointer) passed”) is correctly reported in the controller error queue. However, eventually the controller may reset.
[image1]
Be sure to assign a value to a pointer before assigning it to an I/O point, such as when it is used with a digital or analog point command.
