KB56419
Published: April 23, 2007
‘Set Mistic PID P Term’ with SNAP-PAC-S1 and Mistic I/O units, affects PIDs
SNAP-PAC-S1 Controller Firmware
Problem was discovered in version: R8.0a
Problem is fixed in version: R8.0b
With a SNAP-PAC-S1, when the PAC Control “Set Mistic PID P Term” command is used to set the gain on a Mistic I/O unit’s PID loop, the input variable is also set. This can cause unexpected PID results.
