KB56613
Published: March 27, 2007
Integer 64 and 64-point I/O units with some PAC Control block commands
PAC Control Professional
PAC Control Basic
Problem was introduced in version: R8.0a
Problem is fixed in version: R8.0c
Some PAC Control Action and Condition block commands do not work properly with some Integer 64 variables, literals, and 64-point, I/O unit types.
The PAC Control action block command Bit Test, and the condition block commands Bit Off? and Bit On?, do not work with Integer 64 variables, SNAP-ENET-D64, SNAP-UP1-D64, SNAP-UP1-M64, or SNAP-ENET-S64 I/O units.
The PAC Control action command Read Number from I/O Unit Memory Map does not work correctly when reading into an Integer 64 variable, and the Write Number to I/O Unit Memory Map command does not work correctly when writing an Integer 64 literal or variable.
