KB56685
Published: November 26, 2007
Possible odd behavior from PAC Controllers if numeric literals are passed in subroutines
PAC Control Professional
ioControl Professional
Problem is found in: R8.0a PAC Control, R6.0a ioControl
Problem is fixed in version: R8.1c PAC Control
PAC Control Professional strategies with subroutines that have numeric literals as passed parameters may cause incorrect results, odd behavior, or the controller to reset. This bug may occur when the subroutine is called from an Action block, and is triggered depending upon the combination of parameter types and values passed.
Opto 22 has resolved this issue in PAC Control.
