KB56749
Published: April 5, 2007
‘Convert Number to String Field’ OptoControl command with float value gives incorrect results
FactoryFloor Software - OptoControl
Problem was discovered in version: R4.1c
The Convert Number to String Field OptoControl command returns incorrect results when used with float values. For example, a float value of 0.00001045, when used with the command, returns 891234 in the string field.
Use the command Convert Float to String instead.
Opto 22 is aware of this issue.
