KB56759
Published: April 10, 2007
Table objects in PAC Display Runtime appear to not be selectable
Problem was discovered in version: R8.0c
Problem is fixed in version: R8.0d
Table objects copied from a PAC Display window (Window 1) to another PAC Display window (Window 2) appear to not allow data to be selected in the window it was copied to. For example, if MyTable element 2 in Window 2 is double-clicked, nothing appears to be selected. What actually happens is that the editing window appears in the original window (Window 1), as shown below.
[image1]
When the change is complete, the table elements on both windows are updated.
[image2]
Opto 22 has resolved this issue. The editing window has been corrected to appear in the “copied to” window.
