KB56787
Published: July 6, 2007
Revision: 5.0
MoveIoUnitToNumTable PAC Control/ioControl command may write to wrong table index
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R8.0a
Problem is fixed in version: R8.0b SNAP PAC firmware, R7.2d Ultimate I/O firmware
The PAC Control and ioControl MoveIoUnitToNumTable script command reads the state of all of the modules and points on a serial I/O unit (such as a B3000), but attempts to write data to erroneous table locations, possibly resulting in lost data.
Digital I/O data for the first digital module appears in the first four elements from the starting index. All other digital data is lost. Analog I/O data is stored in the destination table for only the first four analog modules. Data is written to two elements (two points) at a time, with a gap of two elements between each pair of readings.
