KB56847
Published: April 23, 2007
OptoOPCServer returns erratic tag quality if OPC client refers to data item incorrectly
OptoOPCServer
Problem was found in version: R7.0a
Problem is fixed in version: R8.0c
If a custom OPC client or PAC Display client accesses data from a control engine and the data item does not exist in the control strategy, or the OPC client references a data item name incorrectly, then OptoOPCServer does not handle the information returned by the control engine properly. This could include, but is not limited to requesting a tag that no longer exists, or a table index that is out of range.
As a result, erratic tag quality changes occur in OptoOPCServer.
