KB57101
Published: July 3, 2007
Attempts to serially install Ethernet I/O firmware may cause mscomm32.ocx error
OPTODRIVER - Optomux Protocol Drivers and Utilities toolkit
Problem was discovered in version: 1.0b
Problem is fixed in version: 1.0b, 4/19/2007
Attempts to serially download firmware by selecting ioManager, Tools→Install Firmware Using Serial Connection, causes the following error message: "Component mscomm32.ocx or one of its dependents has not correctly registered a file, is missing, or is invalid."
