KB57139
Published: April 27, 2007
‘Switch to Loader Mode’ command in PAC Manager is not supported by all Ethernet I/O units
Problem was discovered in version: R8.0b
Problem is fixed in version: R8.0c
Some Ethernet I/O units are not supported by the Switch to Loader Mode command found in the PAC Manager, Tools→Inspect, Status Write window.
Opto 22 has resolved this issue. A warning message is displayed when an Ethernet I/O unit is not supported by the command.
