KB57142
Published: September 19, 2007
'Write Only' Generic Read/Write fields in PAC Manager cannot be modified
PAC Manager
Problem was discovered in version: R8.0b
Problem is fixed in version: R8.0c
In PAC Manager, if the Generic Read/Write area (Tools→Inspect, Other→Generic Read/Write) is used to modify a 'Write Only' address, then the Value field cannot be edited. A 'Write Only' address is inspected by entering it in the Address field. Clicking on the Value field to enter the value that is to be written, does not allow the field to be selected for editing.
