KB57299
Published: March 18, 2008
Revision: 5.0
SNAP-PAC-R unit watchdog timers sometimes time out unexpectedly
Problem was discovered in version: R8.0a
Problem is fixed in version: R8.1a
Watchdog timers configured on points local to the controller, may time out even though the controller is accessing its own I/O points. Controller communication transactions to its own I/O unit, do not reset the watchdog timer with each transaction. As a result, if nothing else is communicating with the OptoMMP port (default 2001), the watchdog timer times out, and output points related to the watchdog will go to their pre-defined states.
