KB57300
Published: May 7, 2007
‘Condition’ criteria may affect ioDisplay alarm point characteristics
ioDisplay Professional
ioDisplay Basic
Problem was discovered in version: R7.1j
Alarm points can be configured to have a Condition (as seen below in the “Enable” section) met along with the alarm point’s setup criteria. The combination of parameters works correctly if the Condition is met first, followed by the alarm setup. However, if the alarm point setup criteria is met first, followed by the Condition, then some of the alarm point’s characteristics may not operate properly.
For example, a sound turns on and off correctly if the alarm Condition is met first, followed by the setup criteria. But if the setup criteria is met before the Condition criteria, the sound may not shut off.
[image1]
Opto 22 is researching this issue.
