KB57387
Published: May 22, 2007
Window appears to not open when configured graphic selected in PAC Display
Problem was discovered in version: R8.0e
Problem is fixed in version: R8.0f
A graphic with an Operator Driven Attribute to open a window when selected by an operator may not appear to open the window. This could occur if the window has a window property of Always in memory and the window is already open. When the configured graphic is selected, the window does not appear in the foreground and does not have the focus.
To avoid this problem, uncheck the Always in memory option from Window Properties.
[image1]
