KB57440
Published: July 10, 2007
PAC Display error at Runtime if analog points setup for direct I/O unit read
Problem was discovered in version: R8.0e
Problem is fixed in version: R8.0h
If an analog point tag for a SNAP-B3000-ENET is set up in PAC Display to read directly from the I/O unit and not the control engine (Configure→Runtime, I/O Unit Tags tab, I/O Unit tags), then error 0xC0040008 may occur at Runtime.
[image1]
