KB57527
Published: July 9, 2007
'Unable to load Board Objects' message when regenerating I/O scanner tags in PAC Display
Problem was discovered in version: R8.0e
Problem is fixed in version: R8.0h
If a PAC Display project references an OptoControl strategy that has a high density, G4 analog I/O unit, and the I/O scanner tags are regenerated (Tools→Regenerate IO Scanner Tag Names), then the following message is presented "Unable to load Board Objects."
