KB57575
Published: May 23, 2007
‘Find and Replace’ tool in PAC Control may not work correctly in OptoScript blocks
PAC Control Basic
PAC Project Professional
Problem was introduced in version: R8.0a
Problem is fixed in version: R8.0e
The Find and Replace function in PAC Control does not work correctly for OptoScript blocks. From the Find and Replace window, the Replace All button may cause the application to lock up or place the text in the Replace With field in incorrect locations. The Find Next button may incorrectly select random text to highlight.
Use the Find function to manually find and replace text.
