KB57594
Published: August 1, 2007
'Unable to Load Board Objects' message from PAC Display
Problem was discovered in version: R8.0f
Problem is fixed in version: R8.0g
The "Unable to load Board Objects" message appears if the Tools→Regenerate IO Scanner Tags command is run and the PAC Display project references an OptoControl strategy with mistic high density, G4 analog I/O units.
